It is currently Tue Jul 22, 2025 6:46 am
PostPosted: Sun Jul 23, 2023 2:14 pm
Last Name: Colbert
City: Anacortes
I’m pretty pleased with the results. It went really smoothly and the gear I chose for bagging worked perfectly. The glue I used allowed plenty of open time and was easy to clean up. The sides end up about .145” thick, are quite stiff and have almost zero spring back. I’m definitely doing this again!
Cheers, M
Zebra over EIR - Drop-shoulder OM Fan-fret
These users thanked the author Michaeldc for the post (total 4): Durero (Mon Jul 24, 2023 3:33 pm) • Pmaj7 (Mon Jul 24, 2023 12:20 am) • rbuddy (Sun Jul 23, 2023 4:26 pm) • bcombs510 (Sun Jul 23, 2023 3:40 pm)
PostPosted: Sun Jul 23, 2023 2:26 pm
Sometime the vacuum bags look quite appealing. I’ve been clamping with either West epoxy and more recently gorilla glue, but maybe a vacuum system should be a goal…
These users thanked the author meddlingfool for the post: bcombs510 (Sun Jul 23, 2023 4:04 pm)
PostPosted: Sun Jul 23, 2023 3:56 pm
Last Name: Colbert
City: Anacortes
It sure was slick! It provided a lot more clamping force than I had expected. I’m able to easily pull down to 28inHg which, if my math is right, provides about 2000 pounds of force to the surface of the form. I used Unibond One for the lamination, letting it sit overnight before releasing the vacuum. Here is the bag I used https://www.veneersupplies.com/products ... 2-x-4.html . The system cycled once over the 24hr cure time - likely required due to bag stretch. Other than that, the bag doesn’t leak at all. Now to build forms for the four other body shapes I use -
M
These users thanked the author Michaeldc for the post (total 2): Pmaj7 (Mon Jul 24, 2023 12:22 am) • bcombs510 (Sun Jul 23, 2023 4:04 pm)
PostPosted: Sun Jul 23, 2023 4:54 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Yah, ive been laminating the same way for a few guitars. I dont think i will go back to anything else. I love laminated sides.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post (total 2): Pmaj7 (Mon Jul 24, 2023 12:22 am) • Michaeldc (Sun Jul 23, 2023 5:11 pm)
PostPosted: Sun Jul 23, 2023 5:23 pm
Well I’m certainly gonna have room for a vacuum press…
PostPosted: Sun Jul 23, 2023 5:27 pm
First name: Brad
Last Name: Combs
I use a similar setup for laminated lining. I love it. A couple questions:
1) How are you getting it to hold vacuum for that long? I run a Gast pump which means I can only leave it clamped for as long as I’m willing to let the continuous pump run. What’s your setup there?
2) I want to do sides soon, are you pre bending the laminations?
I don’t look forward to making a new set of offset molds for lining and sides, but I’m switching to a new 00 shape after I finish the two on the bench. So that will be a good time to retool it all.
These users thanked the author bcombs510 for the post: Pmaj7 (Mon Jul 24, 2023 12:25 am)
PostPosted: Sun Jul 23, 2023 5:29 pm
Last Name: Colbert
City: Anacortes
You sure are!!!
PostPosted: Sun Jul 23, 2023 5:48 pm
Last Name: Colbert
City: Anacortes
I’m using this venturi style setup https://www.veneersupplies.com/products ... s-Kit.html It’s got a couple small storage tanks that help maintain a constant vacuum once charged.
Yes, I’m prebending the sides. I’m stacking them and bending all at once.
These users thanked the author Michaeldc for the post (total 2): Pmaj7 (Mon Jul 24, 2023 12:25 am) • bcombs510 (Sun Jul 23, 2023 6:52 pm)
PostPosted: Sun Jul 23, 2023 8:36 pm
At least you’ve got a CNC to help you get it absolutely perfect!
These users thanked the author meddlingfool for the post: Michaeldc (Mon Jul 24, 2023 7:41 am)
PostPosted: Mon Jul 24, 2023 11:40 am
This is exactly how I do it as well, to the letter, and I've always had great results. 2'x4' bag, Unibond, and solid forms.
Brad, I use the EVS setup from Joe Woodworker with my pump, which allows you to toggle between cycling and continuous use. One thing I like about the reservoirs is the big initial evacuation of air when you open the line. Since Unibond and West Systems have such a long open time, it probably doesn't really matter if you save a few minutes waiting for the bag to get everything clamped down, but it does provide for an initial flash of action and hiss, which always makes things more satisfying.
I pre-bend the laminates, too. I've used .06/.06, to get a finished product around .125", and that's done me really well.
These users thanked the author James Orr for the post (total 3): Pmaj7 (Mon Jul 24, 2023 7:26 pm) • Michaeldc (Mon Jul 24, 2023 2:44 pm) • bcombs510 (Mon Jul 24, 2023 11:43 am)
PostPosted: Mon Jul 24, 2023 11:50 am
First name: Brad
Last Name: Combs
Perfect. Looks like the EV2 kit comes with the pump and all the parts needed plug and play. I may go that route. I would like to leave it overnight but I’ve not been able to convince myself to leave the continuous pump running unattended.
Thanks!
These users thanked the author bcombs510 for the post: Michaeldc (Mon Jul 24, 2023 2:44 pm)
PostPosted: Mon Jul 24, 2023 12:10 pm
I honestly haven't had luck with the cycling feature and had been thinking about converting to continuous run to save shelf space. Mine tends to run continuously regardless, but Michael's success makes me want to give it more consideration and another look through to see if I may have set something incorrectly.
These users thanked the author James Orr for the post (total 2): Pmaj7 (Mon Jul 24, 2023 7:28 pm) • bcombs510 (Mon Jul 24, 2023 1:33 pm)
PostPosted: Mon Jul 24, 2023 4:37 pm
You will be surprised at how loud it is. I found the tone with double Mahogany has been very well received. Also Rosewood/Mahogany and Rosewood/Maple.
All Rosewood maybe/maybe not. Really loud but perhaps a little throaty. Might be my ears. My specs have been around 0.050 inner 0.060 outer.
I’ll be anxious on your thoughts on completion. Nice work!
These users thanked the author Terence Kennedy for the post: Pmaj7 (Mon Jul 24, 2023 7:29 pm)
PostPosted: Mon Jul 24, 2023 5:22 pm
If it doesn't shut off, you probably have a small leak.
Users browsing this forum: joe white and 25 guests
